Equinox1
Mar 22, 2015Guide
Daisychain the Pro 6
Hi everybody, The ReadyNAS Pro 6 has 2 ethernet ports on the back, and I would to use them in "pass-through" mode. Where I want to set it up, I only have one ethernet socket available, and I would...
Equinox1
Mar 25, 2015Guide
A-ah! itsjasper.... if you band the two ethernet links, as you're suggesting, and connect them to the same switch, you will still have a 1gbps upload :-) And a mess on the buffers at the switch level ;)
