Equinox1
Mar 22, 2015Guide
Daisychain the Pro 6
Hi everybody, The ReadyNAS Pro 6 has 2 ethernet ports on the back, and I would to use them in "pass-through" mode. Where I want to set it up, I only have one ethernet socket available, and I would...
Mar 26, 2015Guru - Experienced User
Just wanted to add that if you want to play with bonding you'd be better off with a managed or "semi-managed" switch, since they have the ability to configure LACP in the switch. For instance the prosafe-plus line from Netgear. The GS105E datasheet claims support for trunking (though it doesn't explicitly say LACP).
ahpsi wrote: 5 port 10/100 switch powered by USB (off the back of the NAS) ~ $25 -> http://www.zunidigital.com/?page_id=182
Or just search USB NIC on Amazon, ~ $9 and up. You could connect each NAS to a separate NIC using static IP's.
Of course Netgear makes a nice 5 port gigabit switch with external power -> http://www.netgear.com/business/products/switches/unmanaged/GS105.aspx#tab-techspecs (they also have the 'home' version, the GS605) but I prefer the design of the GS105.
All would work, switch would be preferable.
Yes, I realized that right after I posted and added some comments on the pro-6. It can saturate a gbps connection.
itsjasper wrote:
StephenB wrote: My advice is to ignore the extra ethernet connection on the RN104. The platform isn't capable of generating/consuming more than one 1 gbps anyway, so bonding isn't worth the trouble.
OP and subject refers to the Pro 6, though his profile does indeed state RN104.
