Equinox1
Mar 22, 2015Guide
Daisychain the Pro 6
Hi everybody, The ReadyNAS Pro 6 has 2 ethernet ports on the back, and I would to use them in "pass-through" mode. Where I want to set it up, I only have one ethernet socket available, and I would...
TeknoJnky
Mar 26, 2015Hero
While I agree it would be awesome to bridge the 2 ports in a (nonstandard) pass-through mode in order to daisy-chain ethernet, unfortunately it really comes down to that you need a switch, both for practical purposes and reliability.
if you want avoid an extra power brick, there are several options of USB powered gigabit switches.
I would recommend against any 10/100 switches, they will be excruciatingly slow if you do large files transfers.
https://www.google.com/#q=usb+powered+gigabit+switch
