ulic_qel_droma
Dec 08, 2016Aspirant
Data gone, no worries about that, just want to use again RN1100
Hello Coucil: Leson learned from long time: ReadyNas is not for single point of recover important data. All my data now is gone, no worries, mirror copy made, and no emergency/disaster for the...
- Dec 30, 2016
ulic_qel_droma wrote:
You were right just as Luke Skywalker about Vader: the screen on the NV+ shows "Bad firmware" while the RAIDar says "Corrupt root"
What's my best next move?
Do a factory default, which will reformat the disks (losing any data, and requiring you to reconfigure the NAS)..
USB/TFTP won't solve your issue, because it is about what's on the disks, not what's in the flash memory.
ulic_qel_droma
Thanks a lot for the quick answer mdgm!
I follow the procedure for USB recovery, Insert USB flash after Rawrite32 image you kindly sent > OFF/ON while power button pressed until 4th blink then just wait... until the NAS auto shuts down, then press power button with USB still connected, but I got same result: no disks detected, no Frontview responding.
I repeat the procedure twice, same result...Am I missing something?
Please advice.
ulic_qel_droma
By the way:
I also try the other USB bays (2 on the back, 1 on the front) with 2 different USB keys form different manufacturer and capacity, also downloaded another .img in another computer and Rawrite32 shows image sent OK to device.
Unfortunately same result, still reporting no disks detected, no Frontview available.
It happens that I have also a NV+ available for cold backup, and I wonder if the 2TB from the 1100 wil lbe compatible with the NV+ running same old 4.1.14 firmware, it's not relevant which box factor will take to duty again, no problem if you ask to forget about that 1U box and move the 4 disks to their new ReadyNas Home.
May the Force serve us well...
- mdgm-ntgrDec 08, 2016NETGEAR Employee Retired
No disks detected would seem to suggest either a PSU issue (not enough power) or all the disks installed failing to the point of not even being detected or some other hardware issue with e.g. the SATA backplane
- ulic_qel_dromaDec 08, 2016Aspirant
Understood:
I start moving the HDD to "new" location at once, the model is Seagate Barracuda ST2000DM001 that appears as compatible on the official NV+ list.
I let you know the resuts.
Thanks again!
That disk model does have very high failure rates but it would seem unlikely that all the disks would have failed so much as to not be detected.
You could hook the disks up to your PC and test them using SeaTools.
