EdjeDek's avatar
EdjeDek
Shares gone
Readynas 104 6.10.2
I remove thuesday the dlna protocol from one of my shares. After this the nas completely frozen, only removing the power was helping.
Now all my shares are gone :-(  All data is still on the disk, but the shares in the readynas admin panel is empty.
Lucky I had made 11 november a Config backup ,now I'm trying to restore this backup, however the readynas will give me the error "error, Unregonized error".
That's not an error that's very helpfull.
What can go wrong here?
Or is there an other way to restore the config backup. (copy the files from the config backup manual to the nas?)
  • Thanks for your reply and time.
    I Don't see error's in the log, will look closer this afternoon.
    Volume's are there and the shares are visible and accessible from my win pc. Every thing looks ok, all data is there.
    However the shares are not visible and therefore not manageable in the Netgear admin panel.
    Solution:
    I added a temporary new share and after that it was possible to restore my Config backup without error's. After the reboot the shares where visible again and everything looks fine again.
    My good old duo RND2000v2 with some external usb hdd making every 2 weeks backup of the RND104, so data is always backuped.
  • StephenB's avatar
    Are you seeing any other errors in the logs?  In particular, are you seeing a full root volume?
    Your data is at risk, so the first thing to do is make sure it is backed up to another device.
    • EdjeDek's avatar
      EdjeDek
      Solution:
      • Marc_V's avatar
        Marc_V
        NETGEAR Employee Retired
        @EdjDek
        This should be resolved by running a script.
        The script finds shares that were accidentally broken in the UI and fixes it. Additionally, performs migration of created folders in the roots of volumes to btrfs subvolume.
        You will have to access your NAS thru SSH and apply the script. I will send it through PM.
        HTH
        Regards
ProSupport for Business
