ulic_qel_droma
Dec 08, 2016Aspirant
Data gone, no worries about that, just want to use again RN1100
Hello Coucil: Leson learned from long time: ReadyNas is not for single point of recover important data. All my data now is gone, no worries, mirror copy made, and no emergency/disaster for the...
- Dec 30, 2016
ulic_qel_droma wrote:
You were right just as Luke Skywalker about Vader: the screen on the NV+ shows "Bad firmware" while the RAIDar says "Corrupt root"
What's my best next move?
Do a factory default, which will reformat the disks (losing any data, and requiring you to reconfigure the NAS)..
USB/TFTP won't solve your issue, because it is about what's on the disks, not what's in the flash memory.
ulic_qel_droma
Dec 28, 2016Aspirant
Hello Stephen, thanks for your message.
The HDD were the previous used at the RN1100 that I'm trying to move to the NV+ ver1 chassis, therefore they preserve the data of that RAIDX arrange.
Should I follow master mdgm's suggestion testing the mem?
What's my best next move? USB firmware? TFTP?
Best regards and thanks in advance for the next advise.
Dec 30, 2016Guru - Experienced User
