ryanku
Jun 03, 2021Aspirant
Data Share Folder Hidden but seen in Root
I can map to the Data folder - its shared. But Unable to un-hide within the readynas admin page. Reset admin password, checked every settings SMB and file search. ty!
Sandshark
Jun 04, 2021Sensei - Experienced User
data is the default volume, so it cannot be changed. Well, I did post a very complicated process for changing it via SSH, but I don't recommend you try it unless you have a very compelling reason. Even then, deleting it, creating a new one, and restoring data from backup is a better solution for most.
