MKGMZN's avatar
MKGMZN
AX4300 broadcasting hidden SSID
I have AX4300 installed for about 4 years. I have one SSID for which broadcasting is NOT enabled. However, the router is broadcasting that SSID as well. I have another "guest SSID" for which broadcasting is enabled.
In the router configuration, SSID for the "hidden" network is still NOT enabled.
How can I stop it from broadcasting the hidden  SSID?
Firmware Version V1.0.16.132_2.0.92
Thanks!
Mike
  • MKGMZN's avatar
    MKGMZN
    Jan 28, 2025
    Thanks for the quick response.
    I have lots of setup/configuration on this router, .e.g, IP address to MAC address mapping.
    I have taken a backup yesterday.
    Can I do the factory reset and then restore using the latest backup? Will that fix the issue?
    Thanks!
    Mike
  • FURRYe38's avatar
    Does a Factory reset and setup from scratch change anything?
    • MKGMZN's avatar
      MKGMZN
      Thanks!
      Mike
      • FURRYe38's avatar
        Try the FR with out loading the backup first and see if the hidden SSID is gone, if so, then load up the back up from file.
  • plemans's avatar
    there's a difference from turning off the wifi on a specific band and whether the ssid can be seen or not (hidden).
    What do you actually have checked off? (screensnips help)
    also, having a "hidden" ssid doesn't always hide it. Its just usually hidden from a built in basic scanner (and not all of them either).
