JochemOnline
Oct 30, 2020Aspirant
DC plug size for ReadyNAS duo v2 (RND2000)
Hi community, I need to replace my power adapter, and unfortunately Netgear does not provide them separately. So I'm stuck with a third party solution, which raises two issues: What is the e...
Oct 30, 2020Guru - Experienced User
It should be 5.5mm/2.1mm. FWIW, there is one here that claims to be compatible: https://www.amazon.de/Adapter-RND2210-200NAS-ReadyNAS-NU60-H120500-I1-332-10122/dp/B08LDSWBRV
JochemOnline wrote:The original European adapter came with an earthed 230V plug. Most replacement adapters have an unearthed plug. Would that be a problem?
No.
JochemOnline
Hi Stephen, thanks for your reply. I've seen other brands too that claim to be compatible, but how can I be sure? It would be best if someone who's been using such adapter can confirm it fits properly. I'd rather prevent having to order multiple models and having to return all but one.
- StephenBOct 30, 2020Guru - Experienced User
Hopefully someone will.
My own Duo's power brick is still working. But I don't have a tool that can measure the plug size accurately.
- SandsharkOct 30, 2020Sensei
I have used third party supplies with a 5.5x2.5mm connector without issue. I do always look for ones that are labled for CCTV camera use, not just LED lighting, as they typically have better power regulation. I have been happy with the Kaystar brand since the brand I used to get is no longer available.
