JochemOnline
Oct 30, 2020Aspirant
DC plug size for ReadyNAS duo v2 (RND2000)
Hi community, I need to replace my power adapter, and unfortunately Netgear does not provide them separately. So I'm stuck with a third party solution, which raises two issues: What is the e...
JochemOnline
Hi Stephen, thanks for your reply. I've seen other brands too that claim to be compatible, but how can I be sure? It would be best if someone who's been using such adapter can confirm it fits properly. I'd rather prevent having to order multiple models and having to return all but one.
Oct 30, 2020Guru - Experienced User
Hopefully someone will.
My own Duo's power brick is still working. But I don't have a tool that can measure the plug size accurately.
- SandsharkOct 30, 2020Sensei
I have used third party supplies with a 5.5x2.5mm connector without issue. I do always look for ones that are labled for CCTV camera use, not just LED lighting, as they typically have better power regulation. I have been happy with the Kaystar brand since the brand I used to get is no longer available.
