user4202
Aug 19, 2022Tutor
Dead RND4000 (ReadyNAS NV+)
Hello, I have an RND4000 (ReadyNAS NV+) that appears to have died. I've replaced the power supply unit and still no action, so I guess it's a circuitry fault somewhere. The unit has a 3-driv...
- Aug 21, 2022
user4202 wrote:
One more question if you can advise - would the differing versions of RND4000 make any difference in being a host for recovery?
Any NV or NV+ v1 model will work. Note the NV+ v1 needs to say ReadyNAS NV+ on the front panel. Don't worry about RND4000v2 or RND4000v3 labels - they denote small hardware revisions of the same platform. Best to test it with a spare disk first. After installing the spare, either match the firmware to your original NAS or install 4.1.16. Try booting the NAS with the spare disk in every slot.
The NV+ v2 (which says ReadyNAS NV+ v2 on the front panel) will not work. Ultras, Pros, or NVXs will not work either.
Aug 19, 2022Guru - Experienced User
The NV/NV+ are the only desktop NAS options for direct migration of the disks. There is at least one rack mount model also. Either way, you are looking at models that Netgear discontinued in 2011, so 10 years old at least.
The drives can be mounted temporarily on an OS-6 NAS, but that requires assistance from Netgear paid support. Several have struggled to get that support recently (many here are thinking Netgear is exiting the NAS business). And Netgear won't support used NAS.
You could get some USB adapter/docks, and then use something like R-Studio to recover the data. https://www.r-studio.com/data_recovery_linux/
Sandshark
Aug 19, 2022Sensei
Assuming your 3 drives are in XRAID/RAID5, you could use a Duo (V1) as well if it's just for file recovery. The volume will show up as "degraded" because of no redundancy, but you should have the same access as you would on a 4-bay system with a failed drive.
