dcline97
Mar 06, 2015Aspirant
Debugging erroneous UPS alerts
We just moved out RN516 from our main computer room to another building and its now on its own UPS (Tripp-Lite Omni1500LCDT). The UPS is connected via USB and when viewing the UPS status in the Ready...
May 09, 2015Guru - Experienced User
My cyberlink uses a normal USB cable, so that is easier to swap out. The custom serial-USB cables can be hard to find and pricey.
I was thinking that you could leave the UPS connected to the NAS, just switch the monitoring for a bit. Then the NAS is still protected from those short outages (which I agree is important). It wouldn't receive shut down messages, but it sounds like your outages are much shorter than the battery limit.
