dannieboiz
Oct 06, 2016Tutor
Deleted snap shots now all shares are gone.
I was trying to save space so I started to stop a bunch of snapshots on drives that I didn't need them on then went on a deleting spree. Now frontview doesn't display any of my shares anymore. O...
Oct 07, 2016Guru - Experienced User
Do you have a backup? If not, this would be a good time to make one.
- dannieboizOct 07, 2016Tutor
Yes I do have more than 50% of the critical shares backed up to an external machine as well as cloud.
I rebooted the system last night and it all came back now the way i tshould. I'm still unable to upgrade the firmware however.
- StephenBOct 07, 2016Guru - Experienced User
Netgear support isn't an option, since this is OS6 on legacy.
It's possible someone from Netgear might want to take a look though.
Did you have ssh enabled? If so, can you still access the NAS that way?
Everything is working fine, I can also SSH to it and login just fine. My issue now is that firmware won't update. tried both auto and manual method. been like that since 6.5.2 was release.
- Mar 31, 2022Retired_Member
