ednorms's avatar
ednorms
Deleting volume on RN104 fails with Code:14004030000
Hi,   Greetings to the Community.  Just need some help on deleting volumes. I am trying to remove the 3Tb disks on my old RN104 4-bay system, and replacing them all with 4Tb disks.  I have removed ...
  • ednorms's avatar
    ednorms
    Dec 09, 2019
    Hi,
    Thanks for the advise.I will do just that. I've had this machine for more than 5 years now, and a disk failed a couple of months back. Unfortunately, i could not find a similar drive with the same capacity from the same vendor. I tried adding another 3Tb drive from a different vendor but it keeps failing to sync.  Anyway, all remaning 3Tb drives are of the same age so I thought it's probably high time to replace all of them, that's why I moved off all the data. Also, I can load them with new 4Tb drives too. I sure hope i can continue to use the machine for a few more years. Thanks also for reminder to wipe off the old disks.
    regards
    Ed
ProSupport for Business
