muddauber
Oct 12, 2022Aspirant
Destination cannot be accessed
My NAS now routinely requires me to run repairs on my backup USB drives, disconnecting and running it on my PC to repair Error backup job job_003 Backup: Destination cannot be accessed By the ...
muddauber
Oct 20, 2022Aspirant
Thank you for your reply.
1) I only eject the USB Drives after I get the error. It never makes it thru the first backup
process even after I run it thru the disc repair cycle.
2) I have both external backup USB drives independently powered.
Is there a solution and/or can you recommend the next step up for a NAS without
these issues?
Oct 20, 2022Guru - Experienced User
process even after I run it thru the disc repair cycle.2) I have both external backup USB drives independently powered.
Can you copy files to the drives on a PC after you do the "repair"?
Have you tried testing the drives in a PC using Seatools?
