shoemoney
Apr 17, 2015Tutor
Disappointed with lack of knowledge of support #25012209
unboxed my 516, installed 6 5tb wd red drives, booted and like a dumbass installed about every plugin (hey I was excited). The web interface went down and reboot whatever wouldn't work. I ca...
shoemoney
Apr 17, 2015Tutor
Well I can tell you what solved all my issues was being able to login as root.
I am a unix vet for over 20 years and I didn't know root login was enabled out of the box.
BTW this is built on debian? love using apt!
I migrated from unraid and while that is fun with slackware and all that it takes a lot of maintenance and upkeep and hacking away. Nice to have something that just works. I can't believe the performance... its quite impressive. I was lucky to get 30mbs out of my unraid box. Copying over stuff from my computers both network ports maxed out cable speed cat 6. Didn't think write speed (especially during sync) would be near that.
