shoemoney
Apr 17, 2015Tutor
Disappointed with lack of knowledge of support #25012209
unboxed my 516, installed 6 5tb wd red drives, booted and like a dumbass installed about every plugin (hey I was excited). The web interface went down and reboot whatever wouldn't work. I ca...
Apr 17, 2015Guru - Experienced User
What you want to avoid is UNINSTALLING apps until 6.2.3 is available/installed. Though since ssh access is enabled, the OP can resolve that bug if he runs into it.
BigBearf wrote: Do not install any apps until 6.2.3 is available.
