Prenko
Feb 19, 2012Aspirant
Disc does not show
I have added a “WD20EARX Caviar Green SATA2 2TB, 64Mb” hard disc to my ReadyNas NV+. It already housed two “Seagate ST3750640NS SATA 750 GB”. In the admin interface, all disks are visible but only ...
mdgm-ntgr
Feb 20, 2012NETGEAR Employee Retired
Both. Backup your data if you haven't already, update to the latest firmware and after verifying the firmware update was successful (should see redesigned web-interface with NetGear not Infrant shown in Frontview: http://www.readynas.com/simulators/frontview/) then do a factory default. Also note that with RAIDiator 4.x the default password has changed: http://www.readynas.com/kb/faq/boot/what_is_the_frontview_default_login_and_password_after_a_factory_default
Your currently installed firmware was released over 5 years ago back in December 2006!: http://www.readynas.com/forum/viewtopic.php?f=1&t=7836
