hario
Apr 26, 2012Aspirant
Discspace 738 Gb instead of 6 TB?
Hello, I have bought a brand new ReadyNas Duo RND2000 v2. With my NAS I bought 2 x 3 TB WD30EZRX Discs which are listed under the Hardware Compatibility List (http://www.readynas.com/?page_id=82). ...
sphardy1
Apr 26, 2012Apprentice
Because there are 2 versions of the Duo - The Original Duo and the Duo v2.
You apparently have bought the original Duo (irrespective of any labels that you might have) which doesn't support drives >2TB, whereas the Duo v2 does support >2TB drives and therefore you must be looking at the wrong information on the HCL
