hario
Apr 26, 2012Aspirant
Discspace 738 Gb instead of 6 TB?
Hello, I have bought a brand new ReadyNas Duo RND2000 v2. With my NAS I bought 2 x 3 TB WD30EZRX Discs which are listed under the Hardware Compatibility List (http://www.readynas.com/?page_id=82). ...
hario
Thanks for your reply. Is there any way I can make sure it's the old ReadyNas? Because If it is the old one i will return it to the shop i bought it from.
