hario
Apr 26, 2012Aspirant
Discspace 738 Gb instead of 6 TB?
Hello, I have bought a brand new ReadyNas Duo RND2000 v2. With my NAS I bought 2 x 3 TB WD30EZRX Discs which are listed under the Hardware Compatibility List (http://www.readynas.com/?page_id=82). ...
sphardy1
Apr 26, 2012Apprentice
You are running 4.1.x firmware which is only compatible with the original Duo so guarantees that is what you have
