satrijoe
Apr 26, 2015Aspirant
Disk 2 really dead? Seeking guidance - ReadyNAS Duo V1
Hi, New to the forum (I did search for an answer but did not quite find the same scenario): My log showed the following messages: Mon Apr 20 13:01:20 EDT 2015 A SATA reset has been performed on ...
satrijoe
Thank you for the quick reply, vandermerwe.
Regarding the backup, I would like to request your advice:
The only computer that I have available is quite old (i.e. USB2 and 10/100 Ethernet) (the other one is company owned and requires any external drive to be encrypted)
In that case, does it make sense to connect the USB drive to the computer or is it better to connect it directly to the Duo? (I understand either one will be quite slow for today's standards).
Question 2: Any recommendation regarding an external 2TB drive for backup purposes?
Thank you!
Thank you!
