satrijoe
Apr 26, 2015Aspirant
Disk 2 really dead? Seeking guidance - ReadyNAS Duo V1
Hi, New to the forum (I did search for an answer but did not quite find the same scenario): My log showed the following messages: Mon Apr 20 13:01:20 EDT 2015 A SATA reset has been performed on ...
Apr 27, 2015Guru - Experienced User
I'd go with NTFS - so you can access the backup data from the old PC - and back up to the old laptop. That should run about 10 MB/s. This will likely take 1-2 days (depending on how full the NAS volume is).
mdgm wrote: In that case it would depend o which filesystem you wish to use on the USB disk. For the Duo it might still be quicker to connect the USB disk to your laptop and use 100Mbit ethernet.
If you connect the drive directly to the DUO and use NTFS, then it will be a lot slower (~2.5 MB/s - 4x longer to back up). Linux formats run 10-14 MB/s - about the same amount of time as backing up to your PC.
