satrijoe
Apr 26, 2015Aspirant
Disk 2 really dead? Seeking guidance - ReadyNAS Duo V1
Hi, New to the forum (I did search for an answer but did not quite find the same scenario): My log showed the following messages: Mon Apr 20 13:01:20 EDT 2015 A SATA reset has been performed on ...
satrijoe
Apr 27, 2015Aspirant
Thank you guys!
I've got about 1.7TB of data to be backed up so I assume it will take a little over 2 days to get it done. (I will go with NTFS with the disk attached to the 'slow' Ethernet)
A final question about portable/external disks. I see a bunch of seagate and WD models available, all in the $90 range. Any advice on what to look for in terms of specs? (I know USB3 is desirable even if my laptop only has USB2)
Thank you again!
Thank you again!
