Castor's avatar
Castor
Disks wil not allocate available space when upgrading disks
I have a RND4000 (ReadyNAS NV+ v1), which I have used with 4 1TB disks until recently. I replaced the disks one at a time with four Western digital disks:  "WB Blue, 2 TB", Model: WD20EZRZ. Altho...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Aug 25, 2016
    1) If the resync to sync the disks sector by sector is still in process that may slow things down a bit. You are using old hardware and the resources needed to run things would have gone up a bit over time. The NV+ essentially uses  pretty much the same hardware (has same CPU and RAM) as the NV we released back in February 2006. Note there is a warning for some options that it's best to use a UPS if you use it.
    2) It uses the web browser's language. If you don't want to change the web browser's language install another web browser and set that one to use English and use that. Our current models give you the option to override the language used in the UI.
ProSupport for Business
