skal1
Dec 15, 2014Aspirant
Do the sshd worth
I would like to know your opinion if sshd worth on a nas system? Inviato dalla mia cabina telefonica
mdgm-ntgr
Dec 17, 2014NETGEAR Employee Retired
I don't think they would be worth it. Gigabit ethernet is the bottleneck.
Also if disks are not on the compatibility list then if you use them you will be denied support.
