tasone
Aug 13, 2021Aspirant
Does not Boot
Hello, I have two Netgear ReadyNAS 2100, and I tried to do a firmware update to the device, but after it was done and rebooted, nothing happened I unpluged and waited a bit and tried again to...
Aug 13, 2021Guru - Experienced User
tasone wrote:
I just leave the device and it looks like nothing is happening to it at all, I cant see it on my network, and i used the netgear to set it up and it cannot find it.
Try powering down and removing the disks (labeling by slot, so you know where they belong).
Then power up, and see if the NAS shows up on your network. RAIDar should also find it, and report a "no disks" status. https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
tasone
Aug 14, 2021Aspirant
Hi,
Yes i tried this, nothing, that tool cannot see the device
Andrew
