DPBauer's avatar
DPBauer
Don't know where to start.... So Lost
Model ReadyNAS 102, diskless - bought used on EBay - can't Register device, says S/N is already registered and I can go no further.
Purchased a Hitachi 2 TB HD on NetGear approved list and installed in NAS 102 – RAIDar indicates that the unit is functioning healthy – BUT – unable to upgrade to the latest version of firmware, multiple downloads and multiple installation attempts.
As long as I'm lamenting on my current status, I thought I had done reasonable study of the ReadyNAS 102, but I'm starting to doubt that I will end up with the configuration I want:
This NAS is part of my Home Network, my needs are driven by my Photoshop files. I have ~1.3 TB of photo files that I would like to store on the NAS, freeing my desktop or laptop's HD from being overwhelmed. In addition, I have 2 USB 3.0 3 TB external drives I would like to plug into the NAS for off-site backup storage. All my Photoshop platforms run Windows 10 and I don't need any file access outside of my own Home wireless network.
If I put the effort in to setting up the NAS 102, is this configuration possible? I would be so grateful for any help to get me going.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    The warranty is for the original purchaser when purchasing from an authorised reseller. Second hand units may be in questionable condition.
    You may need to use this workaround to update the firmware.
    You should be able to do, what you want, yes.
    The 100 series is a cost effective device for use in the home.
    • DPBauer's avatar
      DPBauer
      Many thanks, if the Registration issue only affects Warranty Issues, then I'm perfectly fine with my status.
      Your “work around” worked perfectly!
      If I could impose further, I see on the Admin Page that the device is healthy and it recognizes NAS 102 Hard Drive and the Hard Drive connected via USB 3.0 – How do I manage, manipulate, and move Files and Folders on the NAS as easily as I can for the data on my PC's Drive C:? For starters, I would like to move Folders over to the NAS 102 HD that contain sub-folders. Ultimately, I would like to open images stored on the NAS 102 HD in the Photoshop on my laptop/PC.
      Thanks so much!
      • StephenB's avatar
        It affects support generally - meaning that you will be denied support even if you are prepared to pay for it,
ProSupport for Business
