Arloxx00's avatar
Arloxx00
Follower
Jun 13, 2018
A6100 Genie won't start.
The NETGEAR A6100 Genie is not starting. Driver version is Windows 10 all I get when I'm starting it is a quick flash of the program and after that it just disappear. I downloaded the latest A6100 Software Version 1.0.0.36 and have also tried 1.0.0.32 but both of them are causing the same problem when I'm trying to start it.
  • Went through another windows 10 upgrade so that is probably what messed it up again like last time. So I guess I should re-install once more, annoying.
  • Same problem here, I un-installed and re-installed and that fixed it for a while, but it failed again and need to see if there is a long term fix.
    • co_arch's avatar
      co_arch
      • Blanca_O's avatar
        Blanca_O
        NETGEAR Employee Retired
        Hi co_arch,
        We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
        Blanca
        Community Team
