Arloxx00
Jun 13, 2018Follower
A6100 Genie won't start.
The NETGEAR A6100 Genie is not starting. Driver version is Windows 10 all I get when I'm starting it is a quick flash of the program and after that it just disappear. I downloaded the latest A6100 So...
- Jun 15, 2018
Went through another windows 10 upgrade so that is probably what messed it up again like last time. So I guess I should re-install once more, annoying.
co_arch
Jun 15, 2018Aspirant
Same problem here, I un-installed and re-installed and that fixed it for a while, but it failed again and need to see if there is a long term fix.
co_arch
