dansenior
Sep 30, 2015Follower
Drives/Volume inactive #25827208
I have a RN104. The unit started to disconnect using iSCSI with Windows 10. Had to repeatly reboot NAS box. Finally it never came back up and failed boot. Pulled drives and was able to bring unit...
mdgm-ntgr
Sep 30, 2015NETGEAR Employee Retired
So you have no backup?
You should follow up with support on this one. They would need a contract in place to look into this.
Jedi_Knight
Oct 07, 2015Tutor
I would suggest work with L3 Tech Support and have Dev take a look.
