Esoteric's avatar
Jul 26, 2021
Remove inactive volumes after hard drive upgrade RN104
I have an iMac with a RN104 to keep track of all my design/art files. It was starting to fill up so I upgraded and bought 2 x 4tb hard drives to replace the ones in my RN104.
I put in 1 x 4tb drive and had it sync over 14 hours. Worked perfectly. Then when I put in a second one it came up with the error remove inactive drives.
When I looked on here I get conflicting answers to the solution.
I can't do the ReclaiME because I don't have a PC.
Does the 1 year on call support help with this? I saw it worked for some and others said no. Is it worth me trying, or will I be losing money? If I buy it and they don't help can I get a refund?
Any help with this would be amazing beccause I'm freaking out about losing a decades worth of stuff here.
Thanks,
-Justin-
  • Thanks for the logs Esoteric
    So, here are the events...
    You replaced disk 2 (which was also a dying disk with tons of ATA errors). I can see that had been going on for a while, so I suspect you don't have email alerts setup? In any case, whether by luck or intentional, you replaced the bad disk and the raid started to sync.
    [21/07/22 20:51:22 WEST] notice:disk:LOGMSG_SMART_ATA_ERR_30DAYS_WARN Detected increasing ATA error count: [13955] on disk 2 (Internal) [WDC WD20EFRX-68EUZN0, WD-WCC4M1808373] 11455 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
    [21/07/22 20:51:29 WEST] notice:disk:LOGMSG_SMART_ATA_ERR_30DAYS_WARN Detected increasing ATA error count: [13955] on disk 2 (Internal) [WDC WD20EFRX-68EUZN0, WD-WCC4M1808373] 11455 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
    [21/07/22 20:52:12 WEST] notice:disk:LOGMSG_SMART_ATA_ERR_30DAYS_WARN Detected increasing ATA error count: [13956] on disk 2 (Internal) [WDC WD20EFRX-68EUZN0, WD-WCC4M1808373] 11456 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
    [21/07/22 20:56:20 WEST] notice:disk:LOGMSG_SMART_ATA_ERR_30DAYS_WARN Detected increasing ATA error count: [13956] on disk 2 (Internal) [WDC WD20EFRX-68EUZN0, WD-WCC4M1808373] 11456 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
    [21/07/22 20:57:46 WEST] warning:disk:LOGMSG_DELETE_DISK Disk Model:WDC WD20EFRX-68EUZN0 Serial:WD-WCC4M1808373 was removed from Channel 2 of the head unit.
    [21/07/22 20:57:54 WEST] warning:volume:LOGMSG_HEALTH_VOLUME Volume data health changed from Redundant to Degraded.
    [21/07/22 20:58:45 WEST] notice:disk:LOGMSG_ADD_DISK Disk Model: ST4000VN008-2DR166 Serial:ZGY94XWV was added to Channel 2 of the head unit.
    [21/07/22 20:59:28 WEST] notice:volume:LOGMSG_RESILVERSTARTED_VOLUME Resyncing started for Volume data.
    The raid successfully synced. BTW - StephenB in my experience it is pretty normal for an RN104 to take this long for a raid sync.
    [21/07/23 12:46:10 WEST] notice:volume:LOGMSG_RESILVERCOMPLETE_VOLUME Volume data is resynced.
    [21/07/23 12:46:11 WEST] notice:volume:LOGMSG_HEALTH_VOLUME Volume data health changed from Degraded to Redundant.
    [21/07/23 12:46:11 WEST] notice:disk:LOGMSG_ZFS_DISK_STATUS_CHANGED Disk in channel 2 (Internal) changed state from RESYNC to ONLINE.
    You had correctly waited till the raid had synced and you then replaced disk 1 for new larger disk.
    [21/07/23 13:54:23 WEST] warning:disk:LOGMSG_DELETE_DISK Disk Model:WDC WD10EFRX-68PJCN0 Serial:WD-WCC4J1972758 was removed from Channel 1 of the head unit.
    [21/07/23 13:54:25 WEST] warning:volume:LOGMSG_HEALTH_VOLUME Volume data health changed from Redundant to Degraded.
    [21/07/23 13:56:20 WEST] notice:disk:LOGMSG_ADD_DISK Disk Model: ST4000VN008-2DR166 Serial:ZGY94KA2 was added to Channel 1 of the head unit.
    [21/07/23 13:56:36 WEST] notice:volume:LOGMSG_RESILVERSTARTED_VOLUME Resyncing started for Volume data.
    At this point, you are still good.
    But then 3 mins later we see multiple disks being pulled and added - at this point the raid would have stopped since that is a essentially a multiple disk failure during a raid resync. Do you know why this happened? Were you pulling these disks in and out?
    [21/07/23 13:59:55 WEST] notice:disk:LOGMSG_ADD_DISK Disk Model:WDC WD10EFRX-68PJCN0 Serial:WD-WCC4J1977774 was added to Channel 3 of the head unit.
    [21/07/23 13:59:56 WEST] warning:disk:LOGMSG_DELETE_DISK Disk Model:WDC WD10EFRX-68PJCN0 Serial:WD-WCC4J1977774 was removed from Channel 3 of the head unit.
    [21/07/23 14:03:02 WEST] notice:disk:LOGMSG_ADD_DISK Disk Model:WDC WD10EFRX-68PJCN0 Serial:WD-WCC4J1972758 was added to Channel 4 of the head unit.
    [21/07/23 14:03:44 WEST] warning:disk:LOGMSG_DELETE_DISK Disk Model:WDC WD10EFRX-68PJCN0 Serial:WD-WCC4J1972758 was removed from Channel 4 of the head unit.
    [21/07/23 14:04:44 WEST] warning:disk:LOGMSG_DELETE_DISK Disk Model: ST4000VN008-2DR166 Serial:ZGY94KA2 was removed from Channel 1 of the head unit.
    [21/07/23 14:05:09 WEST] notice:disk:LOGMSG_ADD_DISK Disk Model:WDC WD10EFRX-68PJCN0 Serial:WD-WCC4J1972758 was added to Channel 1 of the head unit.
    Following this, we see multiple drives again being pulled and re-added, several reboots and shutdown - even adding back in the old bad disk 2. I assume this was part of the troubleshooting as you indicated in your original post.
    [21/07/23 14:16:24 WEST] info:system:LOGMSG_READYNASD_ABORTED_NOINFO ReadyNASOS service or process was restarted.
    [21/07/23 14:16:57 WEST] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
    [21/07/23 14:20:09 WEST] notice:disk:LOGMSG_ADD_DISK Disk Model:WDC WD10EFRX-68PJCN0 Serial:WD-WCC4J1977774 was added to Channel 1 of the head unit.
    [21/07/23 14:20:14 WEST] warning:disk:LOGMSG_DELETE_DISK Disk Model:WDC WD10EFRX-68PJCN0 Serial:WD-WCC4J1972758 was removed from Channel 1 of the head unit.
    [21/07/23 14:20:15 WEST] warning:disk:LOGMSG_DELETE_DISK Disk Model:WDC WD10EFRX-68PJCN0 Serial:WD-WCC4J1977774 was removed from Channel 3 of the head unit.
    [21/07/23 14:20:57 WEST] notice:system:LOGMSG_SYSTEM_HALT The system is shutting down.
    [21/07/23 14:24:36 WEST] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
    [21/07/23 14:25:11 WEST] notice:disk:LOGMSG_ZFS_DISK_STATUS_CHANGED Disk in channel 3 (Internal) changed state from RESYNC to ONLINE.
    [21/07/23 14:26:28 WEST] notice:disk:LOGMSG_ADD_DISK Disk Model: ST4000VN008-2DR166 Serial:ZGY94KA2 was added to Channel 4 of the head unit.
    [21/07/23 14:30:43 WEST] notice:system:LOGMSG_SYSTEM_REBOOT The system is rebooting.
    [21/07/23 14:34:16 WEST] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
    [21/07/23 14:35:25 WEST] warning:disk:LOGMSG_DELETE_DISK Disk Model: ST4000VN008-2DR166 Serial:ZGY94KA2 was removed from Channel 4 of the head unit.
    [21/07/23 14:35:31 WEST] notice:system:LOGMSG_SYSTEM_REBOOT The system is rebooting.
    [21/07/23 14:38:48 WEST] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
    [21/07/23 14:41:24 WEST] notice:system:LOGMSG_SYSTEM_HALT The system is shutting down.
    [21/07/23 14:52:00 WEST] notice:disk:LOGMSG_SMART_ATA_ERR_30DAYS_WARN Detected increasing ATA error count: [13997] on disk 2 (Internal) [WDC WD20EFRX-68EUZN0, WD-WCC4M1808373] 11307 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
    [21/07/23 14:52:05 WEST] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
    [21/07/23 14:53:49 WEST] warning:disk:LOGMSG_DELETE_DISK Disk Model:WDC WD20EFRX-68EUZN0 Serial:WD-WCC4M1808373 was removed from Channel 2 of the head unit.
    [21/07/23 14:53:55 WEST] notice:disk:LOGMSG_ADD_DISK Disk Model: ST4000VN008-2DR166 Serial:ZGY94XWV was added to Channel 2 of the head unit
    The raid died when disks we being pulled during the raid-sync. So, my question is; why these disks were pulled just 3 mins after disk 1 was replaced for a new larger disk? You added a new disk 1 at 21/07/23 13:56:20 WEST but then started to pull drives just 3 minutes after. Do you remember this or what caused you to take that action?
    I also observe the NAS being on a very old firmware. While that isn't the cause it should be updated whenever you get the raid back up and running.
    ReadyNASOS!!version=6.6.1,time=1482880160,arch=arm,descr=ReadyNASOS
    What is needed at this point, is some delicate manual raid assembly with all the disks that were in the NAS at 21/07/23 13:56:36 WEST. The new disk 1 added just prior isn't going to help as the raid sync on that disk never finished (as other disks were pulled 3 mins later and the raid stopped working), however the remaining disks that resided in the NAS at that time, should be enough. The raid can be assembled in degraded mode and likely saved without too much trouble but reclaiME isn't going to help you here. It needs manual raid assembly.
    My advise to you would be to bite the bullet and pay Netgear Support for a data recovery contract. Let their Level 3 team try and save the raid. As the lads have said already, please ensure to have backups of important data in the future.
    Cheers
  • StephenB's avatar
    One lesson here is that you need a backup plan for your NAS.  RAID isn't enough to protect your data, it is always risky to have it on only one device.
    Did you hot-swap these drives?  If not, can you provide more details on what you did?
    What are the other drives you are using in the NAS?
    • Esoteric's avatar
      Esoteric
      Tutor
      Hi StephenB
      Thanks for getting back. I did hot-swap them.
      My system before was this in the bays:
      1. 1tb drive 2. 2tb drive 3. 1tb drive 4. empty
      I took out the 2 bay drive while it was on and synced it to a 4 tb drive. So like this:
      1. 1tb drive 2. (new) 4tb drive 3. 1tb drive 4. empty
      That worked fine. Then I replaced the first one my other new 4 tb drive. So it was like this:
      1. (new) 4tb drive 2. (new) 4tb drive 3. 1tb drive 4. empty
      And sometime when it was syncing like this is just switched to the "remove inactive drives". Then I freaked out and tried the original configuration and drives and it said the same thing.
      I thought RAID would be good enough, but now I'm learning that it isn't. I'll be more careful. Not sure the best plan about perfect back ups yet. But I'll look into it after I fix this scary problem first!
      Thanks!
      • StephenB's avatar
        What 4 TB drives did you purchase?  The sync shouldn't have taken 14 hours, so I am wondering if you purchased WD40EFAX (or some other SMR drive).  If they are SMR, you should exchange them with the seller for something more suitable.
        Esoteric wrote:
        Hi StephenB
        Ok.  So 1 TB + 2 TB + 1 TB -> 1 TB + 4 TB + 1 TB -> 4 TB + 4 TB + 1 TB.
        That was suboptimal, you would have gotten more space by adding the first 4 TB drive to slot 4, and then hotswapping one of the 1 TB drives. 4TB+2TB+1TB+4TB would have given you a 7 TB volume, your path only gives you 5 TB.
        I agree with Sandshark's next step.  Power down the NAS, and put the original 1 TB drive back in slot 1.  Then try booting up, and see if the volume mounts.  If it does, I suspect it will do another resync.
        Either way, if that works then you should back up your NAS before you do anything else.  You can do that by purchasing a USB drive (perhaps 8 TB).  You can connect that drive to the NAS, and set up NAS backup job(s), or you can connect it to the Mac and either drag/drop from Finder or use something like FreeFileSync.  Both methods will work.  If you connect the drive to the NAS, use NTFS as the format, so you can access the files from your Mac.
        After the backup is completed, you could try the hot-swap instead - though I suggest hot-inserting into bay 4, which will give you a 6 TB volume instead of 5 TB.
        Getting to 7 TB (using your original 2 TB disk) is also possible, but require doing a factory default - which would require you to reload all the files from your backup.  If you want more info on how to do that, then post back (after your data is safe)!
  • Given you already had multiple drive sizes, you had multiple RAID groups that needed to re-sync.  Unfortunately, the UI doesn't maske that completely clear, and you may have removed a second drive too soon.
    Whether or not a support contract will lead to a solution depends on just how bad things are.  If it gets to the point of "data recovery", that's not covered.  And, no, you cannot get a refund on a contract or recovery is it's unsuccessful.  Most choose a "per incedent" contract, not a year for something like that, but it also does not cover recovery.
    What you are seeing is why Netgear and this forum always recommend you keep a backup of your files, and especially make sure it's up to date before doing an expansion.  Unfortunately, you can get bad drives straight out of the box, and that can cause expansion issues.  And the volume is non-redundant during re-sync, so any small fault (like a power glitch) can be fatal at that point.
    One thing you might try is booting with just the three drives that were in there before you added the second new one, then all four before that if just three didn't work.  Doing so in read only mode via the boot menu adds some extra protection against anything else going wrong.
    This comapny claims to have NAS recovery software for a Mac.  I've not hear oif anyone who has tried it, though: Iskysoft.com .
    Old IT saying:  If you only have one copy of it, you must not think it's important.
    • StephenB's avatar
      No btrfs support, so this won't work.
      • Sandshark's avatar
        Sandshark
        Sensei
        Then I quickly Googled the wrong one.  I did see a couple months ago another company advertising a NAS recovery package that ran on a PC or Mac (and I think even Linux) that included BTRFS.  I'll have to see if I can find it again.
ProSupport for Business
