slprice90
Jan 20, 2020Aspirant
Dropbox Bi-Directional Sync not reliable - ReadyNAS RN626X
Hi, I am having trouble establishing reliable bi-directional sync between Dropbox and our ReadyNAS 626X. Firmware 6.10.2. If the data exists on the NAS, if often won't push ALL of the data to dro...
JohnCM_S
Jan 22, 2020NETGEAR Employee Retired
Hi slprice90,
You can try downloading the NAS system logs then check the dropbox.log. You might be able to find some clues there on why some files on your NAS are not syncing to Dropbox.
