pgjscottieuk's avatar
Apr 19, 2017
HDD Reliability chart
This is a chart which is a follow up to myself mentioning WD drives are not as reliable as i had previously thoughtScreen Shot 2017-04-19 at 09.39.16.png
  • Hello pgjscottieuk,
    Thank you for sharing your information, resolution and/or workaround. We appreciate your contribution to the community.
    Feel free to post any suggestions, questions, recommendations or anything about your NAS that you think needs attention or will help others.
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello pgjscottieuk,
  • StephenB's avatar
    Can you provide your source?
    Personally I see more value in charts that show specific models - there is a lot of variation.  Backblaze does provide useful data on the specific drives that they use: https://www.backblaze.com/blog/hard-drive-benchmark-stats-2016/  Unfortunately they don't use Seagate Ironwolf models or WDC Red Pros.
    Their stats show lower numbers for WDC than yours (also for Seagate).
    • pgjscottieuk's avatar
      pgjscottieuk
      Guide
      This was data provided by Backblaze and i believe they use 4TB drives mainly due to cost per GB and yes you are right they dont mention specific drives i still think the data is of value i do use Red Pro at the mo and plan when necessary to upgrade to Iron Wolf Pro 10TB i do see there is already a 12TB HGST Ultrastar
  • Quitte frankly, without any more information on what the data represents, that chart is absolutely meaningless.  Is that just failures, without regard to drive age?  If so, maybe the ones with higher failure rates are just older.  The WD drives are also under-represented in the population, so a couple of random infant mortalities will have a greater impact on the average than in the brands with more.  And what is the useage?  Similar to yours, or vastly different?  If vastly different, is the statistic even relevant?  Are all similar types of drives (size, consumer/enterprise, low power, etc)?  Same as you use?
    Beware of statistics.  The great thing about statistics is that there are so many of them.  You can pick and choose the ones you want that seem to enforce your position.
      pgjscottieuk
      Guide
      Hey the permutations are endless i just thought it was an interesting chart
    I would like to know if the RED drives fail less than a regular WD drive with various colors of the rainbow.
    Personally, I think it's a little silly to have all these different color drives. Can we just have a regular drive then maybe an enterprise drive that spins faster or something?
    Anyway, RED are supposed to be for RAID, I would like to know if they are any better.
    Thanks.
    • Sandshark's avatar
      Sandshark
      Sensei
      Then you know little about hard drives.  Ignore such use-specific engineering at your own risk.  It really is engineering, not hype.
      The colors are to make it easier on the consumer to choose the right class of drive as specific model numbers change.  Very smart on WD's part, I believe.  Very pro-consumer, especially for the average not-so-technical ones.
      There are Enterprise, Desktop, NAS, Surveillance, and Archive drive types.  Each is designed with a specific class of use in mind.  The NAS drive is a cost vs. reliability middle ground between desktop and enterprise.  Multiple drives spinning in a common housing create both heat and vibration issues.  Aggressive auto spin-down for energy savings can cause problems in a RAID.  But many NAS owners are not willing to pay for (and don't need the reliability of) an enterprise drive.  But they do need to stay away from drives that may cause problems in a NAS. Thus were born the NAS-purposed (Red in the WD rainbow) drives.  More reliable in a multi-drive RAID configuration than desktop models but cheaper and mostly lower power (thus lower temperature, a huge factor in reliability) than enterprise.  WD learned this the hard way in the early years of the Green drives when folks put them in NASes and other RAID arrays and they caused all kinds of problems.  WD got the blame when it was really users chosing the wrong drive.
      When I bought my first Infrant ReadyNAS NV, I really would have liked the option of NAS-purposed drives.  Knowing desktop drives could have problems in a NAS, I went with the significantly more expensive (moreso than today) enterprise drives.  Some 10 years later, all four are still working and had few or no bad sectors when I retired them from full-time use.  But I have little use for those power-hungry 500GB behemoths (they were quite heavy compared to desktop drives, probably for vibration abatement).  So the extra money for enterprise drives over NAS drives (had they been available) would likley not have been money well spent.  I didn't need them to still be working today.  Was it worth the money over desktop drives since NAS ones weren't available?  I think so.  My second NAS, a Netgear NV+, had desktop drives and 2 of 4 failed in the warranty period.  I don't think any are alive today.
      I suspect that WD changed from "Green" to "Blue" for low-power desktop drives because "Green" is used generically for "low power -- good for the environment" and WD did not want to get caught up in a trademark issue where a competitor could claim that "Green" could not be trademarked because of prior generic use.
      • miogpsrocks's avatar
        miogpsrocks
        Tutor
        The I.T. manager of my company told me that RAID is what allowed corporations to make use on standard off the shelf consumer hard drives vs using the enterprise level drives. Any drive is supposed to be ok for RAID however the problem is these so called green drives are absolute garbage.
        They should call these garbage drives. They are like the dollar store product of hard drives which are the bottom of the class.   They are the worse of the worse and I don't think they last in any situation even in a computer as a nonprimary drive.
        Almost everytime I have had a drive fail, it was always been green. To add insult to injury, they don't even save that much power especially to justify having your family pictures wiped out over.  Besides the green drive, I think that any drive should work in a RAID system. Especially when they are in home use and not being used 24/7.  I have my system set to spin down after 60 minutes of no use.
        Anyway, have you found that the RED drives last longer than a standard like Seagate or Hitachi desktop drive?
        Thanks.
ProSupport for Business
