pgjscottieuk
Apr 19, 2017Guide
HDD Reliability chart
This is a chart which is a follow up to myself mentioning WD drives are not as reliable as i had previously thought
- Apr 19, 2017
Hello pgjscottieuk,
Thank you for sharing your information, resolution and/or workaround. We appreciate your contribution to the community.
Feel free to post any suggestions, questions, recommendations or anything about your NAS that you think needs attention or will help others.
Apr 20, 2017Guru - Experienced User
Can you provide your source?
Personally I see more value in charts that show specific models - there is a lot of variation. Backblaze does provide useful data on the specific drives that they use: https://www.backblaze.com/blog/hard-drive-benchmark-stats-2016/ Unfortunately they don't use Seagate Ironwolf models or WDC Red Pros.
Their stats show lower numbers for WDC than yours (also for Seagate).
pgjscottieuk
Apr 20, 2017Guide
This was data provided by Backblaze and i believe they use 4TB drives mainly due to cost per GB and yes you are right they dont mention specific drives i still think the data is of value i do use Red Pro at the mo and plan when necessary to upgrade to Iron Wolf Pro 10TB i do see there is already a 12TB HGST Ultrastar
