benwrigley
Jul 14, 2012Tutor
Duo Memory upgrade
Hi there, I see from the messages here that the compatibility list for the duo is no longer maintained but can *anyone* recommend which memory to use to upgrade to 1GB? TIA Ben
mdgm-ntgr
Jul 14, 2012NETGEAR Employee Retired
Firstly do you have the Duo (v1) or Duo v2? Duo (v1) memory is upgradeable, Duo v2 memory is soldered on and not upgradeable. See How to tell whether I have a Duo v1 or Duo v2 or NV+ v1 or NV+ v2
