Mook1
Aug 10, 2016Guide
Ultra 6 Memory Upgrade Verification
I want to upgrade the memory on my Ultra 6s. I have two. 8GB seems a little pricey so 4B will have tp do. I've searched the forum and want to verify which memory is correct for the Ultra 6. Can someone verify for me before I order?
Also does the Ultra 6 hold one or two memory sticks?
G.SKILL 4GB (2 x 2GB) 240-Pin SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory F2-6400CL5D-4GBNT
Patriot Signature Line 4GB (2x2GB) DDR2 800 PC2 6400 Memory Module Kit PSD24G800K
Crucial 4GB Kit (2GBx2) DDR2 800MHz (PC2-6400) CL6 Unbuffered UDIMM 240-Pin Desktop Memory
CT2KIT25664AA800 / CT2CP25664AA800
Which is/are correct? (If any!)
Thanks,
Dave-
Here you are. It is the ReadyNAS Ultra 6 (Not Ultra 6 Plus), the CPU is the Intel Atom D510. 2x2Gb
- Mook1Guide
I didn't even see this thread which I believe answers my question.
Not used to the new forum layout.
- Mook1Guide
Sorry. That does not answer my question. I thought mgdm's reply verified the question as to what type. It doesn't.
What type of memory do I need for my Ultra 6?
- Mook1Guide
Not sure that previous post does answer my question.
I'd appreciated verification of what memory I need. I hate returns.
Thanks.
That'
Well, when I upgraded my pro-6 a while back I went with Patriot Signature Line 8GB DDR2 800 PC2 6400 Memory Module PSD28G800K That's been in place for about a year, and I haven't run into any issues.
Though I don't know if that will work out as well on your ultra (and it is 2x4GB, not 2x2GB).
- Mook1Guide
Stephen, thanks. So many legacy models I'm just not sure. Ditto on memory. Too many choices. If I weren't ordering online it wouldn't be a big deal for a return.
sotrack, I'd appreciate that. Thank you.
