benwrigley
Jul 14, 2012Tutor
Duo Memory upgrade
Hi there, I see from the messages here that the compatibility list for the duo is no longer maintained but can *anyone* recommend which memory to use to upgrade to 1GB? TIA Ben
pugilares
Jun 03, 2013Aspirant
Bushman007 wrote: I would like to upgrade my Readynas Duo V1 from 256MB to 1024MB, can someone please advise where I can find the HCL?
It's hard to say now. Three days ago I put Corsair VS1GSDS400 into my Duo (SPARC) and it works like a charm.
As you can read on this forum there are many people unsuccessful with this chip and also many happy ones.
It seems the best option is to make sure before you buy, that you can return the chip in case it didn't work and then you try.
