benwrigley
Jul 14, 2012Tutor
Duo Memory upgrade
Hi there, I see from the messages here that the compatibility list for the duo is no longer maintained but can *anyone* recommend which memory to use to upgrade to 1GB? TIA Ben
pugilares
Jun 10, 2013Aspirant
Ok, so it was a honeymoon (shortened to one week this time) and after that I could see that there are problems with the NAS. I put back original 256 MB chip into my Duo and problems are gone. Luckily there was no problem to return the Corsair chip to the vendor.
