benwrigley
Jul 14, 2012Tutor
Duo Memory upgrade
Hi there, I see from the messages here that the compatibility list for the duo is no longer maintained but can *anyone* recommend which memory to use to upgrade to 1GB? TIA Ben
gbe92
Jan 01, 2015Aspirant
I posted on another similar thread (http://www.readynas.com/forum/viewtopic.php?f=110&t=67380) that Corsair Value Select 1GB vs1gsds333 which other reported as being fine did not work on my Duo v1 (I don't know the CL settings of the module, they were not written).
