zmlb20-2's avatar
zmlb20-2
Duo UPS Configuration - adding more than one IP address for monitoring attached UPS?
I have two Duos (V1) that have been humming along for many many years,  One has been connected to an APC UPS and the the other monitoring it.  I now have added a Duo V2 for more storage and would lik...
  • StephenB's avatar
    Oct 08, 2015
    zmlb20-2 wrote:
    HI SteveB,
    Well, first thanks for the speedy reply, and second, I finally got it to work!
    Are you sure your two remotely monitored NAS are actually being monitored by the UPS?  In RAIDar, are the UPS lights all green?
    Yes.  And when the power actually fails they all end up with notifications in the logs.
ProSupport for Business
