RetroRally's avatar
RetroRally
Follower
Mar 03, 2013
Duo v1 - Memory upgrade fail & help
Hi All,
just tried to upgrade the memory in my Readynas Duo V1 using Corsair VS1GSDS400 1GB module PC3200 400mhz and the box starts loading then the min power ligh just goes out and nothing happens.
I really need to upgrade the memory in it as i'm getting the issue where copying to the box is fine, but copying from it is VERY slow. Can anyone recommend a memory module that does work?
Thanks
Andy
1 Reply
  • Hey,
    ReadyNAS Duo V1
    I had the same problem with the Corsair memory module recommended on the forums, with the module installed the Nas would complete the memory test without error but then wouldn't boot-up.
    I've just installed Crucial - CT12864X40B 1GB, 200-pin SODIMM booted up first time and passed the momory test :D
    Marc
ProSupport for Business
