pmcq
Jan 09, 2012Aspirant
Duo v2 & NV+ v2 Official iSCSI support in future release ?
Hi, will the new arm based nas's get official iSCSI support in a future raidiator update? Also does anybody have a timeframe for nfs support which I believe is forthcoming. I couldn't see anything ...
mdgm-ntgr
Jan 09, 2012NETGEAR Employee Retired
Will have to wait and see what NetGear does. Do you already have a v2 device? If not and you need those features, I would suggest getting an Ultra which already supports both of those.
pmcq wrote:
I couldn't see anything in the duo v2 manuals about jumbo frame support. Please confirm support of jumbo frames.
There is no Jumbo Frame support at this time, though with SSH access you might be able to enable it manually by editing /etc/network/interfaces. I don't know if the changes would stick or not and haven't tried this.
edit: Don't edit /etc/network/interfaces. Edit /etc/default/services. There is a line you can add that should enable jumbo frames: "JUMBO_FRAMES_eth0=1" (no quotes). An OS re-install should disable Jumbo Frames if this doesn't work.
Edit: should be JUMBO_FRAMES_eth0-1, I think. JUMBO_FRAMES_eth0=0 indicates that Jumbo Frames are disabled.
