rnas_newbie
Oct 13, 2012Aspirant
Duo V2 FTP Backup Options
I'd like to request a feature that really should form part of the core capability of the Duo V2 (which provides good performance etc) Feature Requested The ability to create a backup job via Front...
Skywarp
Oct 24, 2012Tutor
This would be a feature request, as it's a different device/OS.
If you want, you can raise a ticket for this under your registered ReadyNAS DUO v2, and post the ticket number, so I can pick it up, and raise it as a request.
You can raise a ticket here:
https://my.netgear.com/mynetgear/myOnlineTicket.asp
