rnas_newbie
Oct 13, 2012Aspirant
Duo V2 FTP Backup Options
I'd like to request a feature that really should form part of the core capability of the Duo V2 (which provides good performance etc) Feature Requested The ability to create a backup job via Front...
lev400
Mar 26, 2013Aspirant
Hi
I have just bought a ReadyNAS NV+ v2 and 4x 3TB Hard Drives. It has RAIDiator 5.3.7 on it. I bought this because I wanted to use this as a auto backup appliance for various servers. Before buying I looked up info and found that it supported the FTP protocol and also found guides for making backup using FTP method. Now that I have got the device I find that it cant do remote FTP as a backup source, I am very disappointed and now have a large brick that I can not use for the intended purpose.
If I had known this I would of not gone for Netgear and would of most likely built my own appliance with a old box and the 4 new disks. I can't believe functionality has been removed in newer versions of the firmware.
When can we expect FTP backup functionality restored to the firmware so that I can get this unit up and working?
Thanks
Thanks
