clth
Jan 26, 2023Aspirant
E-Mail notification is blocked by GMail due to duplicate To headers
ReadyNAS with OS 6.10.8. E-Mail alert to my GMail Account is blocked due to duplicate To-Headers: >>> DATA (EOM) <<< 550 5.7.1 [81.169.146.xxx] This message is not RFC 5322 compliant, the iss...
NiveditaP
Feb 08, 2023NETGEAR Employee Retired
Hello clth ,
And welcome to the NETGEAR Community! 🙂
Could you please update your alert configurations.
Root cause of issue can be :
Multiple lines with To tag is added while readynasd sends test message on Multiple Mail Ids, so it is violating the below rule of IONOS Mail Servers.
"The following header lines may only exist once: From, Sender, To, CC, Subject" .
For solving this issue firmware change in Readynasd will be required to remove mutilpe lines with To tag from its Header.
It's very clear this is the limitation of mail system: gmx.de, the mail server rejects the message with multiple receivers.
ReadyNAS is just a client to send message and it works with very common mail services: gmail, and outlook.
We use two config files used for sending test alert message.
1) /etc/msmtp -> for configuration of email server account.
2) /etc/frontview/alert.conf -> for configuration of alert contacts.
Have a lovely day,
Nivedita Pa
Netgear Team
- StephenBFeb 09, 2023Guru - Experienced User
ReadyNAS is just a client to send message and it works with very common mail services: gmail, and outlook.I am using yahoo mail to send alerts, configuring both my yahoo and my gmail address as Alert Contacts I also see blocked messages from gmail due to non-compliant headers in my yahoo email.
Sorry, we were unable to deliver your message to the following address.<XXXX>550: 5.7.1 [98.137.65.148] This message is not RFC 5322 compliant, the issue is:5.7.1 duplicate To headers. To reduce the amount of spam sent to Gmail,5.7.1 this message has been blocked. Please review5.7.1 RFC 5322 specifications for more information. l12-20020a170903120c00b001961fc1ba30si13804779plh.120 - gsmtpSo I think there is a bug here in the ReadyNAS when you have multiple alert contacts.clth: how many alert contacts do you have configured?- clthFeb 09, 2023Aspirant
I had 2 contacts cofigured.
I tried to delete one of them several times, but that didn't work - the second one came up back immediately.
Fortunately Netgear allows direct acces to the whole file system via ssh (I love that feature).
So I took a look at /etc/aliases and there were 2 destinations for default.
After reducing the alias to one entry it seems to work.Thx and best regards
Claus
