gyves1
May 06, 2016Luminary
Eaton Ellipse ECO 1600
Hi,
I have bought an UPS Eaton Ellipse ECO 1600 and connected on my ReadyNAS 312.
The UPS is found by my NAS, but I can't manage it or see detail infos about the UPS (i.e. power status).
Do I need ton install an add-on or an app on my ReadyNas?
I have the FW 6.5 RC2
Thanks
Did you look on the performance tab?
You should see the est. running time and battery charge there (not intuitive I agree).
- gyves1Luminary
Correct, you are right!
I think this feature should more improve in the next FW.
This night at 11:00pm, I had a power cut in my city, I have received a message from ReadyNAS to warn me about the UPC switching in mode battery, then a notice for shuting because the battery was low after 1 hour.
At 2:30am, the power was back...but the ReadyNas still powered off...For me, the ReadyNas should have returned to the previous power state, isn't it?
- gyves1LuminaryJust do it! :-)
As I'm on holiday, or as I'm at offi 3, I can't push on the button to power on the NAS if I'm out of my home...how can I access to my ReadyCloud again without a physical presence? I'm this power back option should be present on Readynas.- StephenBGuru - Experienced User
gyves1 wrote:
Just do it! :-)I don't work for Netgear, so it's not on me.
I would like to see more options here too. It might already be in the idea exchange - if so, you could vote for it.
If you have full access to the remote site, then Wake-on-LAN might be an option. Some folks have asked for assymetric power schedules (powering down the NAS w/o a corresponding scheduled power-up, and vice versa). That's another possible fail-safe.
