mlknez
May 09, 2017Guide
EDA50 SATA version
I am considering purchasing an EDA500 to expand my 8 bay unit. What version of SATA does the EDA500 support? Is the esata access to the EDA500 consideraby slower than just getting another 8 bay uni...
May 09, 2017Guru - Experienced User
Regrettably the hardware manual doesn't give the SATA version. I've seen some reseller sites that say it is SATA-300 - for instance here: https://www.cdw.com/shop/products/NETGEAR-ReadyNAS-5-Bay-NAS-Diskless-w-Exp-Chassis-RN300-500-EDA500-100NAS/2977645.aspx
That translates to 300 MB/s throughput (raw speed is 3 gbps, but the bus uses 8b/10b encoding - that gives you a 2.4 gbps max throughput).
