mlknez
May 09, 2017Guide
EDA50 SATA version
I am considering purchasing an EDA500 to expand my 8 bay unit. What version of SATA does the EDA500 support? Is the esata access to the EDA500 consideraby slower than just getting another 8 bay uni...
mdgm-ntgr
May 09, 2017NETGEAR Employee Retired
Getting a second 8-bay unit would give better performance.
mlknez
May 09, 2017Guide
are there plans for a faster extension chassis like the ED500?
- kevinfor2014May 18, 2017Guide
2017-05-09 12:39 PM
I've been pushing Netgear Management for an EDA700 model , that would offer 7 bays - match the size/color of the RN628/528 & would be a cheaper solution then buying an 8 bay NAS unit.. if you just needed more physical disks (or had older HDD lying around you wanted to use.. -vs- buying new 10TB drives) - that whole conversation didn't go over very well ... & I got the impression even the EDA500 would eventually be discontinued ( newer NAS models only support 1 single EDA500 - older models supported several)
- SandsharkMay 18, 2017Sensei
I would think that EDA500's at $125 on Amazon is the first step in discontinuence -- clear out the stock. Personally, I think a somewhat smarter box that could be connected to the NAS or directly to a PC for data recovery would be more useful, as it could then be a backup device. The EDA500 isn't a viable backup because it's useless without the NAS.
I posted a suggestion to that effect.
