Caesarea
May 03, 2017Guide
EDA500 connecting directly to PC
Before I order the EDA500 Expansion Chassis 5-Bay I want to verify if I can connect the EDA500 directly to my PC with Windows 10. Can anybody help me with this? Is there any compatibity list wit...
- May 13, 2017
The combination EDA500 and StarTech.com 2-port SATA 6 Gbit/s PCI Express eSATA (PEXESAT32) WORKS!!!
But if you connect the second EDA500 to the second port of the PCI, it does NOT work.
Good luck to you all.
Thanks for the responses!
jak0lantash
May 08, 2017Mentor
The EDA500 has 5 bays. Well, iirc, it has 6, but only 5 have a connector in the back.
A DAS could also provide interesting features such as RAID (directly on the chassis). And it works out of the box.
My point is that maybe an EDA500 for $125 is a good deal but not as no-brainer as it may seem.
